Need help
17 Jul 2010
I want to format my new PC (not for cleaning reasons)
Ive got an annoying problem where in every game i see flickering faint white lines, ive posted on multiple forums, no one wants to help me. im out of ideas.
No idea what to do so I just wanna wash eveything away and try and see if it helps
ive bought an OEM Win 7 fom OcUK. will the key provided still work on the same PC ?
Spec:
GTX460 768MB
AMD Phenom II X2 555 BE 3.2ghz
G.Skill 3gb Ram DD3
Monitor:
Refresh rate: 60
res: 1680x1050
LG Flatron W2234S
Everything connected properly, ive got no idea what the *****Don't swear***** is wrong
Youll be fine to use your windows yes
Try formatting, after installing windows download the latest drivers direct from NVidia, dont use disk, if the problem still persists it could be faulty card, you could try flashing the cards BIOS, or if its in warranty simply return for exchange, what make/model is it? In case its a known issue
Before reformat I'd be uninstalling Nvidia Control Center. Booting up without drivers (res will reset to 1024xwhatever) then reinstalling them, checking for the lines throughout.
Tried everything
New DVI-VGA cable
Other monitor
Different drivers
still nothing. The card is on warranty. If I sent it back would they send me a new one ?
I'd try a reformat just incase something's going on. If that doesn't solve you can be pretty sure it's the GPU. If it's in warranty, send it back with the description you gave us. Possibly even link this thread. But be sure to of tried all the suggestions.
S
Tried Formatting last night, no help.
How can I send it back ? is there any thead that describes this process ?
Also would I receive a new card ?
Southern Scotland, just at the border
