Need Help! *Now with pics of finish rig*
Hey all.
So, finally received all my parts from OCuk.
Everything is assembled and put together. all the lights are lit, and the fans a whirring.
But when I hook it up to the monitor I simply get "No signal."
i've tried both Dvi ports. With the GPU screwed in, and not.
Used 1x6pin 1x8pin (1x6+2), and 2x6pin. And even tried using the molex-6pin adapter. Still no joy.
There's a "green" light on the mobo. And the CPU LED is red.
So- where/what, from here? As I amstuck
thanks
Parts:
http://forums.overclockers.co.uk/showthread.php?t=18267844&highlight=el_commi
all identical, aside from the chassis which I had to change to an Antex Df-30
Hey all.
thanks
Parts:
