First of all I am not sure if this is a CPU or GPU related problem, At the moment I am thinking GPU.
So some background :
Asus 1155 Motherboard
i5 2500k ( currently clocked at 4.3 - the past week has been sat at either 4.5 or 5 dependant on what I am doing )
16gb Corsair memory
Palit GTX770
Windows 10
Usually while playing games I am able to stream using OBS. CS:GO would normally sit at around 300fps, DayZ varieing amounts.
The stream would always sit at 30 happily.
Yesterday the new NVidia Drivers came out. I didn't stream at all last night so didn't notice any difference, wasn't even checking FPS in DayZ.
Had an event tonight so decided to stream, As soon as I started it, boom 8 fps on the stream and around 50% less in DayZ.
Loaded up CS:GO to check that, even with out streaming I am struggling to get a stable 50.
Although when I get shot and it shows who killed me, the frames jump back up.
Could this be down to drivers?
I have tried reverting back to previous drivers however there seems to be no difference.
I have also tried a stress test on CPU and it is fine. I have stress tested the GPU however as I had not previously done this I do not know if the frame rate is any different. No artifacting though.
Thanks in advance.
16gb Corsair memory
Palit GTX770
Windows 10
Thanks in advance.
