Need Idea's For A Gaming Build (i3 Intel) HELP
7 Feb 2014
Wolverhampton
I Bought An i3 Processor For £30 Today And Need Help With What Would Be The Best For Gaming.
Need Help With:
Motherboard
Power Supply
Ram
Graphics Card
Thanks For Reading This :D:D
More info would be nice, most important which i3 is it as without that info can't tell which socket it is so can't suggest motherboard. Also what's the budget
wouldn't a 270 card be better? have that cpu paired with a 7850,its ok in most games but struggles with bf4
yush.. it would. easier on his psu too and he saves some ££.
here you go again: YOUR BASKET
1 x Sapphire Radeon R9 270X Boost OC 2048MB GDDR5 PCI-Express Card £143.99
1 x EVGA 600W 80 Plus Bronze Power Supply (100-B1-0600-KR) £49.99
1 x Avexir Core Blue Series 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Memory Kit (AVD3U16000904G-2CW) - Blue Light £49.99
Total : £253.57 (includes shipping : £8.00).
as for the motherboard or RAM just pick a certain colour you like and go with it.. you don't need z77 because i don't think you're going to be considering any overclocking at all and all motherboards have no difference in performance just features (e.g better CF speeds, free wifi etc)
Thanks :D
I Was Thinking Of This Motherboard
No competitor linking. If you want to link to the manufacturer then that is fine. Thank you.
What You Reckon?
GuyCalledPolly please remove the link in your post and check the FAQ regards competitors.
