need memory advice
29 Dec 2009
Hi guys
Just ordered parts for my new build have the following:
ASUS M4A77TD PRO 770 Socket AM3 8 channel audio ATX Motherboard -
Item: AMD Phenom II X2 550 Black Edition 3.1GHz 6MB L3 Cache Socket AM3 Retail Boxed Processor
Item: HIS HD 5770 1GB GDDR5 DVI HDMI DisplayPort PCI-E Graphics Card
Item: Antec 300 Three Hundred Case -
Item: Antec TruePower New 550W Modular PSU - 80plus Bronze and SLI Certified 3x SATA
Item: Samsung SH-S223 22x DVD±RW DL Internal SATA 3 Bezel Drive - Retail Box & Software
Item: Seagate ST3500418AS 500GB Hard Drive SATAII 7200rpm 16MB Cache - OEM
dont have main memory yet though cause i am confused as what to pick :( wanted the G skill ripjaw 4g but that seems to be discontinued, just wondering if u guys know what would be compatible for the motherboard i have listed
your advice will be valued :)
thank you
Off Topic:
How come you picked an AMD 770 chipset instead of an AMD 785G?
The board got recommended by a friend as he has had it 6 months without problems :) thanks for the memory examples, now need to pick one :)
