Need mobo with PCI Express x8 Slot
22 Oct 2002
I need some help with finding a mainboard which has apart the PCI Express x16 Slot for the VGA another Pci Express Slot x8 for a Raid Card.
Do the mainboards which have 2 x 16x Slots allow me to use the second slot for the raid controller?
Current Spec is.
C2D 6300 @ 2.8Ghz
Gigabyte 965P-S3 Mainboard
1GB x 2 DDRII 800Mhz
X1950Pro
You could try the 680i based boards, but any SLI board should do it - just run both slots at 8x - with my Asus 650i I would have to flip the SLI paddle to do that
Running the GFX at 8x isnt likley to affect performance to much
EDIT : As the 680i boards are 2x 16x then running the mobo in SLI mode should do the trick
The raid card in question is a Dell Perc 5/i Controller and it needs a Pci Express x8 slot.
Do any of the new P35 boards support a x16 VGA in the first slot and 8x in the second slot if both are populated?
Dieni said:
Do any of the new P35 boards support a x16 VGA in the first slot and 8x in the second slot if both are populated?[/IMG]
No, the second slot is restricted to x4, and only if you've got no x1 cards in the other remaining slots.
Jokester
Are you on crack? Does that look like a PCI-E card to you? :D It's a PCIe card and will work in the PCIe slot irrespective of the VGA card in the x16 slot.
Thanks a lot for your help.
If the raid card runs at 4x it should be more than enough, I am just planning a 3 disk raid 5 array for the moment.
Btw, since the card has an x8 interface, will it fit without problems in a x16 slot?
Lol, but as you can see, the interface is larger than that of an PCIe x1 slot ;)
Quote from Dell Website
"PERC 5/i
PERC 5/i is a PCI Express based SAS RAID controller that provides enterprise class protection and performance for supported PowerEdgeTM servers. The Dell PERC 5/i is used to connect internal hard drives in PowerEdge servers and PowerEdge SC servers. PERC 5/i utilizes high performance SAS 3 Gb/s technology to connect to the hard drives, and the latest generation of host interface technology, PCI Express (PCI-E). With support for RAID levels 1, 5, 10, and 50, PERC 5/i provides multiple protection options to suit a wide range of applications. For non-critical data, RAID level 0 is also available.
No but Asus supposedly will have a couple of top-end P35 mobos that will run dual x8 using an additional chip to reconfigure the lanes.
Indeed, just put in in any pci-e x16 slot.
Robbie G said:
A RAID card using the second graphics slot? Am I misunderstanding? I thought a RAID card would be a PCIe card using the little slot.
A pci-e x16 doesnt have to be a graphics slot :rolleyes: , its just like pci, any pci-e device can use any pci-e slot as long as the pci-e slot is fast enough to support it...
The raid card just uses the pci-e interface that is fast enough, my guess it pci-e x4 and x1 were too slow for it, so it uses x8...
