Need monitor advice please.
27 May 2007
Front of the monitor
Hi guys and gals,
Presently I have 3 Dell UltraSharp U2412M screens and thinking about adding a 4th monitor, just a tad bigger one, the Dell UltraSharp U3014. But it is a bit pricey, hence need some advice.
Since the Dell monitors I have is 16:10 I been looking at around 30inch screens with same ratio, presuming it would be best to keep them all within the same aspect ratio, is that a correct assumption ?? Or could I add a 21:9 monitor or would that look all messed up ??
Also, I have a Sapphire Radeon R9 290 Vapor-X card presently in my machine, would that be enough for 4 monitors (although it says it can run 4 no clue if it also has to do with the size of them, i.e. can run 4 x 20 inch screens ok but 4 x 24inch or above would struggle ?? :confused: ) Or would I have to add a 2nd card to run on occasions 4 monitors at the same time and if I have to add another, then I guess my present PSU wont be enough, which is a Corsair HX750 ??
If anyone has any other recommendations of larger monitors that would fit with my current ones I am all ears, especially if it could end up being less money spent on it. :o
Any and all suggestions will be greatly appreciated !! :)
