I see that there's a selection of cables at http://www.overclockers.co.uk/acatalog/Online_Catalogue_Other_Cables_153.html
My mobo is Abit an8-sli
My PSU is Enermax Noisetaker 600W
I'm using NBFAN to power my vf900, and my SYSFAN (front) and AUXFAN (rear) to power my 120mm case fans, and CPUFAN for my CPU fan of course.
(the 2 Q-OTES 3pin connections doesnt make my fan move, maybe it's disabled for the non fatality versions)
I want 1, possibly 2 more 120mm fans inside the case. Would it be safe to use Akasa AK-FY320 3 Pin Fan cable splitter (CB-013-AK)
in my AUXFAN and NBFAN slots? the case fan is the standard black akasa case fan. I'm afraid that the 3pin connections cant handle a vf900+case fan, or 2xcase fan.
Are there any alternatives such as a cheap 4 pin powered fan controller that also suppliers power to the fans it controls?
