Need more ethernet sockets
28 Sep 2004
Buckinghamshire
Currently using BeBox with my home network and even though I have enabled the 4th socket on the BeBox I need at least a couple of additional sockets so I can connect up my new Blu-Ray player for BD Live and my PS2/3 for online use.
Will a simple £10 ethernet switch be OK or should I need to look out for something a bit better?
TIA.
Any make in particular? I used to have a Netgear router until I changed to Be ISP and now just use the Box they sent. Take it I only need up to 100 not 1000mps.
Any half decent switch should do, both those ian has linked to should be fine.
We've currently got 2x 8 port switches connected to our router ;) (although we only really use about 6 ports normally (one switch is next to the router, the other in another room - it saved running a second cable).
