Well recently i have installed Vista 64 bit Home edition i did notice after that that it ain't that fast as i would like it to be, however it was still okay for me ! But when i tried Crysis Demo i really felt i need more Ram because of lag i get sometimes it sort of runs quite smooth but i get a small lag spikes time to time! So i need you advice how and what would be best solution for my memory update !
EE6600 @2.9 atm
Asus P5W DH Deluxe
OCZ 2x1gb PC5400 667mhz
Ati 2900XT 512mb
And this is exact ram i got OCZ 2gb(2x1gb) PC 5400 Gold GX XTC series EL-DDR2 (OCZ26672048ELGEGTXT-K) which is 667mhz i belive but i oced it a lill bit! The question is would you recommend to me get 2 more gig of same ram from here (Old link was here )
or would you recommend better to buy http://www.overclockers.co.uk/showproduct.php?prodid=MY-086-OC&groupid=701&catid=8&subcat= which says: Dual Channel Vista Gold Series DDR2 Does that mean it will run much better in Vista or something why it says Vista, maybe the ram i got now slows my sistem down ?
Any recomendations folks ?
cheers
vai
EE6600 @2.9 atm
Asus P5W DH Deluxe
Ati 2900XT 512mb
cheers
vai
