Need my wheels aligned?
Permabanned
7 Nov 2006
Nottingham
Hey, so i went to the Peak District in my e90 M Sport yesterday and hit a pot hole while pulling into the pub. I now have the following.
Steering pulling to the left.
Steering wheel not centered.
Steering feels lighter / weird
The Gap between the tyre and the arch is 2cm bigger on the left than the right hand side. ( Don't know if its always been like this )
Does this sound like it just needs the wheel alignment done or could it be something else like the suspension?
Sounds like you've probably bent something, better to identify the damaged part and replace it than try to mask the problem with an alignment
