- 4 Jan 2008
Im trying to build a new setup but with a tight budget of around £200, max £300
I'll be connecting it to a 40inch full HDTV. To HD playback is essential. I want it to be as quite as possible and i was hoping it to have the E5200 at least.It will be used to watch movies and tv shows and dvds. It will also be used for word processing, and internet. Another thing that was essential was it to play high quality loud music, so if you have any speaker recommendations, that would help (on top of budget). I was first just going to buy a dvd home system with amplifyer of upto 850w, but i also needed a cheap basic pc. So i was wandering if a pc can be made with similiar capabilities of both in one.
If can't be done within my budget, what would you recommend with a higher budget.
