Need new case help, Quiet, RGB, Window, White, £130ish
18 Oct 2002
West Midlands
I need a new case but not sure as been out of loop for while.
Needs white colour, window, rgb lighting (on case and fans), silent, midi size or greater, around £130 or less.
I have looked at BeQuiet 500DX White which is great but out of stock, the Phanteks 500A RGB is nice but I read the fans are loud and not sure if I can make them quite enough to not hear them using my mobo fan curves?
It will run a AMD 5800X or Intel 110600 and something around a GTX 3080.
Thanks.
P400A is a quiet case, built in it about 2 months back, no fan curve needed.
Lian li lancool ii mesh is a great case also but I would recommend the performance edition.
I can 100% vouch for the be quiet 500dx, my personal rig is in this case and its whisper quiet, cooler than a penguin sat on an iceberg with mega air flow which it houses a 5600x and a 3080 tuf oc which are not cool component's
Thanks! As 500dx is out of stock everywhere I am leaning towards the fractal define 7. No Rgb but ticks very thing else. Any views?
The r7 is a good case as all fractal cases are but, this is my opinion, not as good as the 3 I listed earlier.
I pre ordered and just waited for my 500dx. I am glad I did as the temp drop in my component's was mind boggling.
Going from an nzxt H500 to the 500dx my gpu temps dropped by over 10c and my cpu temps by around 15c with also a monumental noise reduction.
My case is also paired with the dark rock pro 4 which together keep the cpu temps and noise level to just a whisper
