need new case...
Permabanned
10 Jun 2005
ok i want a new case, has to be able to fit 120mm cast fans front and back at least i would like it to hav a window or be able to have a window bought for it later on. i would like it for have around 4/5+ 5.25" 3 3.5" external 4+ internal 3.5"
A note about the pc-7x range of cases is that you don’t actually need the front fan installed to keep things cool.
Removing the fan from mine cost me a whopping 2c on CPU temps *shock*
The fan is there to cool the hard drives though; and it depends on your system to how much of an effect it will have.
Hard drives if your running 3 raptors is asking for trouble in the case without the front fan. Or running SLI without the front fan is not advised.
2 x 36GB raptors and a x800XT-PE, happy as can be :p
Placing hand on front of the grill you can still fill a pull from the rear fan and the negative pressure bubble it’s attempting to balance so drives still have air passing by them.
