Hello,
I currently have a thermaltake kandalf case which is about 5-6 years old, my gpu (580GTX) can't connect to the case correctly as the i don't think the case allows for 2 slotted cards. The screws don't line up correctly. I have botched this was cable ties which for now is working fine.
The case is taking up quite a bit of room so i would like something a little smaller (and lighter).
Needs to be able to fit my gpu in
1 2.5" ssd, 1 3.5"hdd and normal size mobo/cpu etc.
Use external DVD writer so don't need loads of space for them.
Any recommendations?
