So had the EK loop connect..... Software is total trash, doesn't need a tweak or two but to be totally redone. EK are not supporting the product saying to go for complete refund and get something else from another manufacturer after 35 emails. If you like rgb that works when it wants, software that can't find your hardware 50% of the time, can't use Gigabyte fusion rgb software at all or even have reminent files of it on the system for say gpu rgb, fans that spin but pump that randomly doesn't work on start up and software that crashes with no error messages that either keeps everything at pwm 40% or completely stops while gaming/rendering while you're afk (thank god for auto shut off) then its great for you!! Plus mine has a broken drgb port and another 1 that only gave out 50% power which meant that 1 or 2 fans where red randomly on the 3 way splitter for that port.
So after nice phone call to Overclockers they recommended:
https://www.overclockers.co.uk/lamptron-sp901-argb-pwm-fan-and-rgb-controller-black-fg-00u-lp.html
But its motherboard controlled which is okay for rgb (AsRock) but wanted software for pwm fans and pump to do nice custom curves accessible on desktop for specific run very hot tasks and some nice rgb effects. Temp Sensors would be nice too. So my RL friend said to get SpeedFan but he's aircooled and doesn't know if it will work for the pump. Does anyone use SpeedFan for a watercooled pc or know of good software for this?
I've the Phanteks P500A which has its own ARGB controller built in again motherboard controlled but doesn't have pwm at all (EK Vardar fans currently daisychained to it plus a splitter with pump and flow indicator drgbs, runs fine but nothing great).
I really like the Corsairs Commander Pro on paper but I've heard it only works with corsair fans and nothing says what kind of rgb connection it has like 4pin rgb or 3pin a/drgb. ICUE software is great as I use it for RAM. Is anyone using this with EK Vardar 120EVO DRGB Fans or remembers what rgb connections it has? I'm assuming 4pin.
Price isn't much of an issue but I don't want a Digital display at all and preferably something mounted at the back and out of view.
