Need new front tyres
15 Nov 2002
I have a 2007 Fiesta which currently has 4 Bridgestone ER30 fitted. The size is 195/50/R15 82H.
My front tyres have worm right down to the tread indicators so they will need changing now. My back tyres still have loads of tread left.
When I search with my reg number on Kwik-Fit it seems to think I would need a V speed rating when the tyres I have fitted are H.
Would it matter if I installed V speed rating tyres on the front? Also what tyre would you recommend? As I heard the Bridgestone ones are not that good :eek:
Been looking at the Uniroyal RainExpert ones they seem to have good reviews http://www.tyrereviews.co.uk/Tyre/Uniroyal/RainExpert.htm
Continental Premium Contact 2 :)
Or if you want some super sticky ultra high performance tyres, Goodyear Eagle F1s :cool:
