following on from my previous thread
http://forums.overclockers.co.uk/showthread.php?t=18022210
i now no exactly what i am looking for and would appreciate some advice please
i am looking for an Nvidia GEforce Graphics card that can handle HD easily, has 2 outputs ( VGA and DVI ) isnt expensive and is quite, i dont mind a small fan but not a jet engine or i would be happy with passive but heat may be an issue so a small fan would be preferable and it must have a 2pin s/pdif input header on it, which i think most Nvidia GEforce cards have, also it needs to be PCI-E
what i dont need is onboard audio processing, just the 2 pin s/pdif header for audio pass through amd it will never be used for gaming just HTPC work
appreciate some recomendations guys please
