need new sound card for gaming
23 Sep 2008
hi guys as it says going to upgrade my sound card for gaming ,i have got a budget of £140
tower space i have 4870x2 an 4 sticks of ram on asus rampage formula x48,
i am using the asus superfx sound card at the min an the case is a antec 1200 gaming case.
so just want a hand on what card to get cheers
Xonar D1 and if you fancy some headphones too a pair of HD555's would be make a great combo. ;)
You could spend some extra on a Xonar D2/X, but for gaming alone you'd be hard pressed to tell any difference.
got a HOTAUDIO USBDAC from a well know auction site the quality is amazing and the price is unbeatable its perfect for stereo set-ups and headphones
If you have £140 to spend then get a Xonar D1 and Sennheiser HD555.
That will be a massive upgrade and within your budget, much better than keeping the Fatal1ty and buying a more expensive version of the Xonar. :D
