ok i havent bought a new pc for quite some time now so im a little behind on whats worth buying and whats not etc so im looking for a bit of help..... Basically i have about £300 to spend and some new bits for a PC but i already have the following parts which i think will do for now? i want to be able to plug the pc into my tv via hdmi (optical in + out would be really handy aswell) and needs to be as quiet as possible for my budget. all i really use it for is watching high def movies and playing WoW occasionally, sooo what can you recommend?
Current Spec
Intel Core 2 Due E6300 @ 1.86ghz
4x DDR2 6400 1GB sticks of ram
2 x Sata2 HDDs which need to stay so no need for a replacement
1x DVD writer (dont need new one)
thanks in advance
Current Spec
thanks in advance
shamefull i know!
