need peoples help on 7" tablets android.
12 Dec 2006
Hi all
Basically im looking for a 7" plus tablet pc running on android, purely for keeping an eye on my ebay sales and watching the odd film.
I don't really want to go above 150 as im sure anything at the moment will just be a stop gap till next years offerings.
So I think I have narrowed my search down to either a storage options scroll or the disego 6000? Dose anyone know which is better value or more reliable.
Im also open to other options anyone has a good suggestion.
For that price it's probably the better machine, if I was you tho I'd spend an extra 80 quid and get an Archos 70, almost purely for the capacitive touchscreen, but also the huge amount of video files it's able to play.
Thanks for the reply. In the end I went with the scroll as I managed to find one in a shop locally. Not too bad a build quality an for only £120 I thought it would do till google release something.
I did look into the vega and archos 101 but their few and far between thats if you can find them...
To be honest the screen isnt that bad at all, then again I dont get on to well with the captive screens as I press to hard. But the reistive screen is slower so thats the down side.
