Need pointing in the right direction...
14 Oct 2007
I am trying to put something together in my job for the rest of the team...
I want to be able to create a form, that will give you radio buttons to select, for example:
Issue Type 1
Issue Type 2
Issue Type 3
Etc
When you select Issue Type 1 for example, it will list questions to ask. I also wondered if it would be possible, to make the user fill out the answer to the questions once asked, and then summarise at the end the questions asked and the answers given, so they can be copy and pasted in to another system as call notes.
Any one know what application I would use?
Tried to google it but can't google it fully if I don't know exactly what i'm after, if that makes sense?
You could do that it in Excel or Access.
I suggest those only because they are apps that most people have on a work machine, probably more so Excel.
However, it's not basic stuff and if i'm being honest, if you have to ask the question you probably don't have enough experience to do it easily and quickly.
If time is no issue then it's probably a nice project to try and learn some VBA or advanced Excel functions, i always find people learn more easily given a real life issue versus exercises in text books.
