I'm having trouble finding the size of this PSU, is this model the same as the [SS-550RM] ? it appears to be the same thing with all the information I can find about this product... Most PSUs of this wattage appear to be under 160mm long but I would like to make sure.
>>Link<<
Also will this be enough power to supply this spec?
Gigabyte ATi Radeon HD 7950 Windforce 3X 3072MB GDDR5 PCI-Express Graphics Card
Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST2000DM001)
Pioneer BDC-207DBK 8x BluRay ROM / DVDRW SATA-II Optical Drive - Black (OEM)
Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/8GX)
BitFenix Spectre PRO 200mm White LED - Black
Antec Kuhler H2O 620 Liquid Cooling System
Microsoft Windows 8 64 bit OEM, WN7-00403, English Version
Intel 3rd Generation Core i5-3570K CPU (4 x 3.40GHz, Ivy Bridge, Socket 1155, 6Mb L3 Cache, Intel Turbo Boost Technology 2.0)
Samsung 840 Series Pro 256GB 2.5 inch SATA Solid State Drive
Gigabyte Z77N-WIFI Motherboard (SKT 1155, Mini-ITX)
Sorry if any of my questions seem stupid, never built a PC before.
Thanks
>>Link<<
Thanks
