Hi,
Current build;
AMD Phenom II x4 925 @ 2.8Ghz (I am going to be buying a 1100T soon)
Current PSU: Based 300w that comes with the Mesh Matrix II 925
GPU: Radeon HD 5450 1Gb
HDD: WD Caviar Green 500Gb 7200Rpm
Mobo: Asus M4A78LTM
Memory: 4Gb Elixir DDR3 1333Mhz
I have ran the PSU calculator and it recommends 277w for my current setup
My thoughts;
PSU: SuperFlower Amazon 450w
Cooler: CoolerMaster Hyper 212
Memory: 8Gb TeamGroup Red (Best timings that i've seen for £50 RAM)
Would you make any suggestions to the PSU, Cooler or Memory? £100 budget.
I know you would normally suggest getting another mobo, better cpu, ssd, gpu etc but I feel they are adequate. I plan to overclock the CPU and memory to 1600 which my board supports (Standard 1333).
If I get the teamgroup memory should i crap my existing memory as it is basic ram so the timings will mess things up for the teamgroup memory right?
Thanks,
Current build;
Mobo: Asus M4A78LTM
My thoughts;
Thanks,
