Need quick lesson in case selection
18 Aug 2006
ChCh, NZ
Does any PSU fit in into any case, if not, what do I look out for?
Does any mobo fit into any case, if not, what to look out for?
No.
No.
PSU - some of them are too large to fit into smaller cases and rhe case requires some modding to get them to fit.
Motherboards, well there are loads of different size/shapes, some cases only take certain types of board, I forget the names of them though.
InvG
mini atx
micro atx
atx
extended atx
those are motherboard standard sizes and chck the specs of the case to see which is supported. usually an atx case can be used with mini and micro as well (not at same time ofcourse :p) extended atx are usually reserved for servers iirc.
33L
