yeah I kept eveything that came in the box with it so thats a relief LOL.
Thanks
CB
Hi
For that I'd recommend this motherboard, Gigabyte Z77X-D3H. It's the latest Z77 chipset, and supports SLI/CF at 8x/8x![]()
Urgh Gigabyte nasty
I'd get this > http://www.overclockers.co.uk/showproduct.php?prodid=MB-064-AK&groupid=701&catid=5&subcat=2261
Well, i did get this and wow brilliant board![]()
Dot get that board. I was gonna but then found it only supports pcie 2.0. So in 5 years time when you wanna slap in cheap Ivy B. in and use pcie3.0 you have to get a nother board. But if you spend few quid more and get Gigabyte Z77X-UD3H. It has pcie 3.0 and few other bits and bobs that make it a great long term upgradeable platform.
I am so good with this. Arek
http://www.gigabyte.com/products/product-page.aspx?pid=4144&dl=1#spThe PCIEX16 slot conforms to PCI Express 3.0 standard.
Umm, you do know ASrock are a budget brand don't you? So i'd regard ASrock as nasty rather than Gigabyte which are a decent mid range brand
Personally i'd get an Asus board
http://www.overclockers.co.uk/showproduct.php?prodid=MB-513-AS&groupid=701&catid=5&subcat=2261
Where did you get that from!? From Gigabytes website:
The 3rd slot running at 4x is PCI-E2 only, but that's no big deal!
