Need recommendations for a sub £100 GPU
12 Jun 2010
Near Sheffield
As it says in the title, i am in the market for a sub £100 graphics card, mainly for Microsoft Flight Simulator X.
I am unsure of what is the best out there for the money as this will be for my first build. Also, the graphics card needs to work with a Corsair 400w PSU.
If anyone could recommend a good graphics card for that price, preferably one that you may already use with FSX, it would be very much appreciated.
Thanks in advance :D
Would recommend the 5770. Just got it and it's amazing, though I think the 5750 is just a bit slower clocked, so it should still perform really well!
There isnt a massive different between the 5770 and the 5750.
There are some benchmarks here: http://www.tomshardware.com/reviews/radeon-hd-5770,2446-14.html but I would get the 5770.
Thanks for that info:D
Looks good, how much of a difference does half of the memory make?
I bought a 4870 from the MM for £65.
Unfortunately i can't get onto there yet, i'll have to try ebay...
