Need recommendations for a wildlife/trail camera
Caporegime
29 Jul 2011
In acme's chair.
One of those that you put outside and it shoots infrared lit video at night when it senses movement.
I bought the one that had the best reviews on Amazon, this one: https://www.amazon.co.uk/dp/B09Y8V268F/ and it is absolute trash. Absolute trash. It somehow fills the entire 32GB card with about 2 minutes of HD video, intermittently complains that there is an issue with the card and doesn't record anything, and the app is completely non functional. You cannot view or delete recorded video via the app whatsoever.
I need something that preferably will connect to my home WiFi, and then I can access via WiFi on an Android device anywhere in the house, to view and manage any footage it takes with an app that isn't complete dogwater.
Any recommendations? Budget is 'sort of' not a concern, but lets keep it below silly money, say £300 - £400 tops.
Thanks!
I use a blink outdoor camera with the local box so I don't need the subscription. You can power from USB permanently or they run on single use lithium.
