need rough budget/ spec
9 May 2007
i not very updated with my hardware was hoping some one may be able to tell me what kinda specs/ budget will i need to play crysis 2 on say a 20" screen i think its 1680x1050 res?
£1K should do it.
Dont need to spend that much, imo
2 options, AMD/ATi bit cheaper, Intel/NVidia bit better, nothing stopping you having AMD/NVidia or Intel/ATi BTW - It is also worth noting this AMD spec supports xfire (not SLi) which would allow for adition of 2nd card in the future, where as the Intel would be single card set up only
AMD/ATi option
OcUK ATI Radeon 6950 2048MB GDDR5 PCI-Express Graphics Card £209.99
AMD Phenom II X4 Quad Core 955 Black Edition "125W Edition" 3.20GHz (Socket AM3) - Retail £109.99
Corsair TX 650W ATX SLi Compliant Power Supply (CMPSU-650TXUK) £67.99
Foxconn A7DA-S 3.0 AMD 790GX (Socket AM3) DDR3 Motherboard £54.98
Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD103SJ) £41.99
GeIL 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz VALUE PLUS Dual Channel (GVP34GB1600C9DC) £37.99
Coolermaster Elite 430 Windowed Case - Black £35.99
Akasa AK-CCX-4002HP Venom CPU Cooler (Socket LGA775/LGA1155/LGA1156/LGA1366/AM2/AM3) £35.74
Pioneer 24x Internal S19LBK DVD Rewriter including Labelflash SATA Retail £19.99
Total : £614.65
Intel/NVidia option
Gigabyte GeForce GTX 560Ti OC 1024MB GDDR5 PCI-Express Graphics Card £209.99
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - OEM £171.59
MSI P67A-C45 Intel P67 (Socket 1155) DDR3 Motherboard - (Sandybridge) £89.98
Total : £711.24
How have you managed to spec a pc for a game thats not released yet? and no system specs to run it at good settings have been released?
crystal ball?
Ahh missed the 2 part, fair point, but both these should still be capable, though I know Crysis 1 crippled most PCs. Though conversely how have you managed to give a budget then? :p
A 1K budget will get the best stuff on the market:p
How do you know those two specs are capable?
I dont, anyway enough arguing, you seem very argumentitive this past week or so Stulid
I misread the OP, missed the 2 part in Crysis and the way I read the OP was he was after a capable gaming machine for a reasonable budget
Yes to the OP, whilst the 2 specs above are capable gaming machines, certainly for your res, no one will be able to do an accurate spec until the game is released and/or benched which ever happens first
A grand will definitely do it (assuming you need to replace everything and want to maximise lifespan).
Crysis 1 recommended specs:
OS - Windows XP / Vista
Processor - Intel Core 2 DUO @ 2.2GHz or AMD Athlon 64 X2 4400+
Memory - 2.0 GB RAM
GPU - NVIDIA GeForce 8800 GTS/640 or similar
IIRC, that was propoer hardcore for 2007. Assuming we're talking a similar situation, ideally:
2500k
4gb
GTX570
Memory - 2.0 GB RAM
That has to be the minimum surely, or rubbish low settings so it looks like lego blocks
Hot off the press :D of EA Germany
Crysis 2 will require at least:
•A Core 2 Duo or Athlon 64 X2 processor clocked at 2GHz
•2GB of RAM
•A GeForce 8800 GT or Radeon HD 3850 with 512MB of video memory
•9GB of hard-drive space
•DirectX 9.0c-compatible audio
•And, of course, a keyboard and mouse (Xbox 360 controllers will also be supported on Windows).
