Need some advice if i should RMA my 260gtx
23 Mar 2007
Essex
Hi i bought a 260gtx from here around 2 weeks ago but i keep having a strange problem when i boot up my pc my graphics card wont seem to load after the windows logo, i can hear the windows tune in the background so to me the computer has booted fine but has no image. I have sinced changed drivers i went to 182.50 all seemed ok only once it did not boot, i have now upgraded to the 191.00 drivers and im now getting the problem again, they always say use the most up to date drivers, so what i want to know is, is it the card do you think or the drivers? it never happened on my old 8800gts
thanks
i just had a look on the giga site for an updated bios but i think mine is running the latest one according to there site 62.00.50.00.02, going to go back to the 182.50 drivers i guess and see how it goes for a week or two, if i still get the prob then i will rma for sure, ocuk i really good with there rma's good work guys!!
If it works fine with the 182 drivers then you should just stick with those...
::edit::
Ignore this post, I see you are going to use them for a couple weeks, it really does pay to read the entire thread instead of the first couple of posts!
I have the same problem when turn the system on there is no singal on monitor(Dell 2407WFP). It's GIGABYE GTX260. I wasnot at home, so haven't try any solutions provided. May try it later. I had thrown the original package is it okay for RMA?
had the same problem with my gygabyte 260 gtx , pleas try them individually , ive taken mine back to overclockers , they tested mine ,one was faulty ! i got a refund and changed the cards for two different ones
