Need some advice on 22-24" Monitors
5 Jan 2010
London
Hi there,
I've got several monitors short-listed in my mind, but not quite sure what to go for.
I'm using the screen for 2 things, via these connections:
DVI to PC
HDMI to Xbox
Apart from that, a VGA connection would be handy, but not needed.
I'm looking at an LED screen, with the response time of under 5ms.
An important factor is that it must be adjustable to some extent, with the budget of around £150 in mind (I could get a stand separately).
I've also looked a bit into the technology - and I think IPS is better than TN for me. I might be mistaken though - source:
http://reviews.cnet.com/2719-7610_7-200-2.html
So what do you guys suggest?
Atm, I have short-listed the:
LG IPS235V
Asus VE228HR
Cheers!
