- 5 Jan 2010
- London
FINISHED but feel free to comment.
Hi guys!
Been a LONG time since I've been on these forums.
I've been relatively happy with my current PC build (which is dated a little) - but here are the specs:
ASUS P5K Premium
E6500 @2.93ghz OC'ed to 3.53Ghz (Dual core)
Nvidia 7600GT (256 Mbt)
2GB OCZ DDR2 Platinum @ 800 Mhz
Artic 7 Cooler
ASUS PW201 Monitor (8ms with 1080i @ 16:10 ratio)
To keep (hopefully) and pass to the new build:
Xonar D1 soundcard
Edimax EW-7728In (N-Draft)
I am wanting to upgrade and build a PC (or get it pre-made for hassle-free + on-site warranty)
Here's what I'm thinking of building/upgrading to:
CPU
-I5 3570K
Motherboard
-ASUS SABERTOOTH Z77
RAM
-Corsair Dominator 2x 4GB Module CL8 @1600Mhz = £68
GFX
-GTX 660 TI 2GB
-SAPPHIRE HD 7850 OC
Drive
-Sony Optical drive X22
Power Supply
-Corsair AX850 (850watt)
OR
-Seasonic X-Series 760w
OR
-Corsair TX850M (850watt)
Case
-Fractal R4 Titanium
CPU Cooling
-Antec 920
Storage
-120GB SSD Corsair Force GT (6GB/s) = Already Bought
-1TB to 2TB of 7200RPM HDD = Already in use with current system and got
Display
-Monitor (undecided) but looking at a IPS LG 23" Monitor at the moment
I will be using the system mainly for browsing, emails, YouTube, video rendering (I make a lot of YouTube videos, but nothing my current system can't handle) and maybe in the future some gaming (I haven't gamed since BF2142 - been awhile, as I have the Xbox 360 for that)
So my questions are the following:
-Should I go for the i5 over the i7, considering it is £80 cheaper for my needs? From what I've seen/researched and experience with my current system, I think maybe an i7 would be over-kill, but I don't know. ANSWERED
-What PSU would be good enough for this type of system (incl brand), and would you suggest modular/semi-modular or not? ANSWERED
-What monitors should I be looking into?
I preferably want an LED, with a high contrast ratio, under 5ms response time, have DVI/HDMI and possibly VGA connections.
It has to be a native 1080P, and be in-between 22" and 27" - preferably spending under £150 for it.
Will ask in the Monitor section.
-RAM wise, is there any other recommendations?
I was going to go with 16GB Corsair Vengeance 1600Mhz, but thought against it, and got advised by a friend to go for only 8GB.
I also thought not to go over or below 1600, as it would either be too slow, or overkill for what I'll be using my system for.
More input would be greatly appreciated
ANSWERED
I would also like the system to be on the relatively quiet side
Hi guys!
ASUS P5K Premium
Artic 7 Cooler
Xonar D1 soundcard
CPU
-I5 3570K
Motherboard
RAM
GFX
-GTX 660 TI 2GB
Drive
Power Supply
OR
OR
Case
CPU Cooling
-Antec 920
Storage
Display
ANSWERED
