- 22 Jun 2012
- Leeds, UK
Hi guys,
I'm basically changing my loop and case, from just the cpu & gpu being under water to:
Complete motherboard
Ram
Gpu (gtx 6790, overclocked)
Cpu (3930k, overclocked)
Currently i've got a tripe and a dual rad in a cosmos ultra but that case is massive & totally unusable as i have to move the rig from uni and back all the time..
Anyway
, i'm wanting to get a TJ07 and i know they have support for a quad 120 rad in the bottom and a 360 rad in the roof (with a bit of cutting). I've also heard that it is possible to get a 240 in the bottom behind the quad, but i'd rather not do that because i'd like to keep my pump there.
Clearly it would be best to have the 360 rad in the roof along with the quad in the bottom, but im just wondering if the 360 is really needed? It would take 10-15 days for the mod and its rather expensive
So can anyone advise if a a single quad rad is enough for my rig? I would in the future like to add another 690 (when i can get one cheap)...
Thanks!
Ram
Anyway
Thanks!
