Hi
I'm looking to do do a much needed update to my pc but I haven't kept up on hardware for quite a while and I'm not sure about what I have picked out/chosen to delay buying and could do with some advice. Either way I'll have to settle for a partial upgrade for now and finish it off later when my bank balance has recovered...
The reason I want to upgrade, or at least what prompted me into action, is much the same as last time I did a big update... I got a new game (batman arkham city) and for the first time in years, my pc can only just about handle it on lowest settings and I'm not having that! (bioshock / dx10 was to blame last time). I could probably get it running better with some tricks or something, but I'm already on a mission to buy now. I guess most of my pc is 4 years old now, so I guess I got my moneys worth seeing as it still runs a most games with pretty high settings.
I also have a small home studio setup and do a fair bit of multitrack recording w/plugins that eat up resources etc. and due to my sound card, firewire is a must
My HDD's suck now too, but I can't be bothered dealing with sorting out all my data, so I'll sort that out later. thinking of getting a smaller SSD for caching (not right now though).
I definitely need a graphics card, but it's that or pretty much everything else and I'm not sure which is going to make the more noticeable difference.
motherboard wise, I was sold on the Asus maximus IV Gene-Z till i realised it didn't have firewire and even though I don't think I'll like be running sli, I will get a new graphics card some time and then probably bump my current one down to dedicated physx meaning I wouldn't have space for a firewire card
I'll probably do a bit of light overclocking, but not likely to get too deep into it. Might partial watercool later.
Musts:
i7 CPU - pretty set on the 2700k but open to suggestion. Does this come with stock heatsink/fan? will consider better later, but I got lots of case fans, so not fussed as long as I have something.
8GB RAM minimum - I could live with 1600mhz if it's considerably less and great performance
On board sound - I don't like it, but I have to run that into my pro card so I can dedicate pro card to audio software (without windows messing with it) and use same speakers.
space for 2 large pci e graphics cards, might be a while before i buy another card so gen3 mb
Currently in my basket:
Intel Core i7-2700K 3.50GHz (Sandybridge) Socket LGA1155 Processor - OEM **BLACK FRIDAY SPECIAL DEAL** £249.95
Asus P8Z68-V PRO GEN3 Intel Z68 (Socket 1155) DDR3 Motherboard £169.98
G.Skill RipJawsZ 16GB (4x4GB) DDR3 PC3-14900C9 1866MHz Dual/Quad Channel Kit (F3-14900CL9Q-16GBZL) £104.99
Total with delivery: £536.32 - way more than I should be spending...
Currently running:
Coolermaster Stacker 830 Nvidia case - Air cooled with 7 120mm fans (some generic ones)
Enermax Infiniti 720W
MS Windows 7 Ultimate 64-bit SP1
CPU:
Intel Core 2 Duo E6750 @ 2.66GHz 62 °C
Conroe 65nm Technology
RAM:
6GB Dual-Channel DDR2 @ 432MHz (5-5-5-18)
-4GB OCZ Reaper 1066mhz DDR2 (2x2GB)
-2GB DDR2 (2x1GB) of something else 1/2 decent I got given for free, can't remember brand
Motherboard:
ASUSTeK Computer INC. P5K (LGA775) 48 °C
Graphics:
SAMSUNG 40" Samsung LE Series 7 TV (1920x1080@60Hz) - my monitor is broke and everything looks too awesome on this ('cept for the tearing) to bother doing anything about it...
768MB GeForce 8800 GTX (XFX Pine Group) 63 °C
256MB GeForce 8400 GS (Undefined) 47 °C - for physx, since I got it free
SLI Disabled
Hard Drives:
313GB FUJITSU MAXTOR STM3320620AS ATA Device (SATA) 37 °C
245GB Maxtor Maxtor 6L250S0 ATA Device (SATA) 35 °C
977GB SAMSUNG SAMSUNG HD103UJ ATA Device (SATA) 29 °C
Optical Drives:
SONY DVD RW AW-G170A SCSI CdRom Device
Audio:
High Definition Audio Device (for general sound)
Presonus Firebox (firewire pro sound card)
Redundant parts I would be using if I could:
BFG Ageia Physx card (f*ck you nvidia for buying and no longer supporting it in newer drivers)
2nd 768MB GeForce 8800 GTX (XFX) - got for free, as it had coffee spilt on it (how you do let that happen to what was still a very nice card back then I don't know). bsod's me when using it, not sure if faulty or if it's because it's a bit loose in slot, or because I'm one 6pin power cable short and having to use an adapter, oh and I'm missing the bridge too.. can't sli on this mb anyway (sli patch didn't work/same bsod). I'll try it again on new board with the other bits sorted.
Don't know if anyone will manage to respond before I'll have to order, but I'll appreciate any responses anyway.
Thanks
p.s. 1st post, so apologies if it's in the wrong area or I've done something else wrong
Musts:
Currently running:
CPU:
RAM:
Motherboard:
Graphics:
SLI Disabled
Hard Drives:
Optical Drives:
Audio:
Thanks
