- 2 Jan 2010
I'm about to sell my loyal shuttle on ebay in order to make way for a pc that has more headroom for upgrading. In terms of cases I've considered getting a q07 but was a bit put off by the lack of space there is for a graphics card (as far as i can tell you can't fit a dual slot card in there).
I found the sg05-450 which seemed ideal, but am a bit worried by the huge grill on the top (don't want a load of dust in me pc!).
Can anyone suggest a few good cases? Ideally I'd want it to cost under £80 (or £120 if it comes with a good power supply), good construction (preferably aluminum) and it needs to be able to fit a dual slot graphics card (standard length is fine, not anything ridiculous!) . Oh and mini itx just to clarify
Thanks in advance!
