im going to buy the x1800xt if not x1900gt [256mb] and looking for some better cooling been looking into water cooling as i already have bigwater 2 already i know it not the best out there but
its doing a great job cpu doesnt go over 45-50c load o/c-38idle compared to fan/heatsink 55-60load.......well anyway i thought about getting a gpu water block but then i thought since it only a bigwater it wont have the pumping power to go to the gpu aswell as cool down [getting next week]my x2 3800 and also the hassle of draining the coolant without spilling it.............
so i sought out for a solution which involves watercooling still but seperated from current water setup....
does anyone know the max heat wattage an x18../1900xt../gt?
as this review [below link] says it can dissapate 120watt
well here it is!!
Thermaltake CL-W0052 Tide Water All in One VGA Cooler
Thermaltake Tide Water is the ultimate solution for water cooling your noisy graphics card, whilst also providing extra overclocking potential. The Tide Water All In One VGA Liquid Cooling module is one of the best graphics coolers on the market today, in a robust, sleek design. Everything is pre-assembled for a no hassle installation and a basic but brilliant refilling method.
- Brazing copper Waterblock
- Suitable for nVIDIA and ATi GPU
- All copper designed Radiator
- Adjustable Fan (1700 , 2500 RPM /17 , 19dBA)
- Black Powerful 12 V Tiny Pump
- 10,000 hours of maintenance free from liquid refilling
http://www.techpowerup.com/reviews/Thermaltake/TideWater/
seen around for £50.............is it a good choice or are there others better
thanks for looking oh overclockers buy these in
its doing a great job cpu doesnt go over 45-50c load o/c-38idle compared to fan/heatsink 55-60load.......well anyway i thought about getting a gpu water block but then i thought since it only a bigwater it wont have the pumping power to go to the gpu aswell as cool down [getting next week]my x2 3800 and also the hassle of draining the coolant without spilling it.............so i sought out for a solution which involves watercooling still but seperated from current water setup....
well here it is!!
