17 Feb 2010 at 14:07 #1 coxroach1 coxroach1 Associate Joined 13 Dec 2007 Posts 115 Hi All, I am looking for a case that is capable of housing a large ISA card. it is roughly 13 1/2 inches long. Ideally I do not want the case to have any 'bling bling' lights etc and at the lowest cost possable. Thanks All Last edited: 17 Feb 2010
17 Feb 2010 at 14:38 #2 PermaBanned PermaBanned Soldato Joined 7 Jul 2009 Posts 16,234 Location Newcastle/Aberdeen You're not going to get cases that size cheap. All i can think of is this: http://www.overclockers.co.uk/showproduct.php?prodid=CA-157-CM&groupid=701&catid=7&subcat=29 and even then i'm not entirely sure.
17 Feb 2010 at 16:07 #3 James Manns James Manns Associate Joined 20 Nov 2009 Posts 489 i would agree with that, maybe even one of those silverstone raven things because they are longer than they are tall.
17 Feb 2010 at 16:38 #4 Sildeh Sildeh Associate Joined 2 Jan 2010 Posts 305 Location Liverpool It should fit in a 932, great case, can't fault it.
17 Feb 2010 at 16:41 #5 Diggsy Diggsy Soldato Joined 31 Aug 2007 Posts 4,939 Pretty much any case with removable HDD bays should do the trick.
