After trying and failing to install it the 'complicated' way (making the libraries myself from the source code) I eventually gave up and installed it with the precompiled libraries. (this isn't the problem but it might have some bering on it so i figured i'd let you know).
I have followed the instructions to get openCV up and running in visual studios 2010 express and i am now trying to get the sample code at the bottom of the page running.
When i try to build it with the sample code as is, it will give me the error: cannot open include file 'opencv2/imgproc/imgproc.hpp'
When i change the paths in the "#include" lines to the full path imgproc seems to work but I get the same error with core instead. ie: cannot open include file 'opencv2/core/core.hpp'
I know the paths are correct because I've physically checked them about a million times now. I've even tried changing the slashes from forwards to backwards since win7 seems to think they are backslashes when i copy the full path as text and the sample code thinks i should use forward slashes
Any suggestions would be much appreciated because I've tried various solutions from people on the internet with exactly the same problem and nothing seems to work.
