Ok I was waiting for the z68 boards and theyve finally arrive...
I need some advice as to whether the components I have chosen are the best for their price. ie
The ram, should i go for another brand or is this fine, I chose this one based on the fact it had a lower CL rating which im assuming will make it easier to overclock with.
I went for the i7, because I want something that will last me a while. I know i dont need it
It is a gaming machine.
Why is the gigabyte motherboard 300 whilst the asus was 170 odd... I probably would have gone for the asus if it was in stock so if there is no difference between the two boards I can grab that part off another etailer.
Should i pay the extra and go for a different brand gtx580? I know gainward used to have a good rep but last I heard they had gone downhill somewhat.
I settled for the antec khuler 620 as i dont really want to wait on the 920 stock to come in.
I chose the case because it looked pretty spacious and i need a full tower as I want to put a few hds in it. I also like the simplicity of its design. It looks sleek. Is there anything better for the money or slightly more?
I intend to order this pretty soon as I want to build it before the witcher 2 comes out
