Need some expert advice on system to build :-)
30 Aug 2006
Hi all,
I am about to put a general purpose machine together .. used for general purpose activities and multimedia stuff
(photo's, movies, video's, music etc..) but with some future proofing built in so's it's not too archaic after 6 months :-)
Perhaps someone can give me an idea if the list below will work together and give me roughly what I am after.
The things I'm not too sure about ..
  • is the memory suitable?
  • good choice of mobo and cpu?
  • and I want a quiet set up .. so is the case up to it?
Any suggestions would be well received ...
Yer tis ...
MSI K9N Platinum nForce 570 (Socket AM2) PCI-Express DDR2 Motherboard (MB-070-MS) £64.99
Seagate Barracuda 7200.10 320GB ST3320620AS SATA-II 16MB Cache - OEM (HD-078-SE) £59.95
AMD Athlon 64 X2 Dual Core 4200+ 2.20GHz (Socket AM2) - Retail (CP-168-AM) £109.99
Sapphire ATI Radeon X1300 Pro 256MB DDR2 AVIVO TV-Out/DVI (PCI-Express) - Retail (GX-111-SP) £46.99
Arctic Cooling T2 Silentium Midi Tower Case - 350W Seasonic Silent PSU (CA-001-AR) £47.95
Crucial 1GB (2x512MB) DDR2 PC2-5300C5 Dual Channel Kit (CT2KIT6464AA667) (MY-083-CR) £62.99
Subtotal £392.86
VAT £68.76
Total £461.62
Thanks guys,
Dave
This:
OcUK GeForce 7300 GT 256MB GDDR3 HDTV/DVI (PCI-Express) - Retail (GX-040-OK)
Is faster than the X1300 for the same money.
Three (3) things:
  • GFX chosen not very good, better aim for at least the NVIDIA 7300GT;
  • G.Skill/GeIL RAM is equally good if not better & cheaper!
  • & heard of Intel Core 2 Duo (see here)? If your budget is roughly £500, you can spec a better system than the one above!
EDIT: Word has it that the Arctic Cooling T2 Silentium Midi Tower Case isn't that silent :( Better of getting something else with 'effective' cooling & also a beffier PSU!
Here...
  • GeIL 1GB (2x512MB) PC5300 667MHz Value DDR2 Dual Channel Kit (GX21GB5300DC) (MY-030-GL) £59.99
  • Intel Core 2 DUO E6300 "LGA775 Allendale" 1.86GHz (1066FSB) - Retail (CP-126-IN) £116.99
  • Asrock ConroeXFire-eSATA2 (Socket 775) PCI-Express DDR2 Motherboard (MB-003-AK) £53.99
  • OcUK GeForce 7300 GT 256MB GDDR3 HDTV/DVI (PCI-Express) - Retail (GX-040-OK) £49.95
  • NEC ND3550 16x16 DVD±RW Dual Layer ReWriter (Black) - OEM (CD-035-NE) £19.95
  • Antec Sonata II Piano Black Quiet Case - 450W Smart Power PSU (CA-040-AN) £65.95
  • Seagate Barracuda 7200.10 250GB ST3250620AS SATA-II 16MB Cache - OEM (HD-079-SE) £49.95
  • Subtotal £416.77
  • VAT £72.94
  • Total £489.71
the T2 is quiet. but not silent :)
also, the integated PSU is the bain of my life. the only thing that has stopped me buying anything new for 18 months...because I have to get a case and a PSU as well :(
