- 21 May 2003
hi. I'm trying to write a program (very simple) which takes the length of the sides of a triangle and tells you waht the triangle is (equilateral isosceles etc)l.
here's the code so far:
module Triangle where
import Char
triangle :: Int -> Int -> Int -> String
triangle a b c =
if sorting a b c /= a
then triangle b c a
else
if a == b && b == c
then "Equilateral"
else if a >= b + c
then "Impossible"
else if a == b || a == c || c == b
then "Isosceles"
else if a*a == b*b + c*c
then "Right Angled"
else if a /= b && a /= c && c /= b
then "Scalene" else "zero"
sorting :: Int -> Int -> Int -> Int
sorting a b c =
if a > b && a > b
then a
else b
Problem is, i need to implement the "read" function so the lengths can be inputted with quotes. the read will simply convert the string to numbers.
at the moment is works fine if you input the numbers without quotes. if anyone can help i'd appreciate it this is very simple stuff but i can't work it out.
import Char
triangle a b c =
then triangle b c a
else
if a == b && b == c
then "Equilateral"
else if a >= b + c
then "Impossible"
then "Isosceles"
then "Right Angled"
sorting a b c =
if a > b && a > b
then a
else b
sorry for the useless comment
