- 17 Apr 2009
- Liverpool
Hiya, about 1 year ago now I bought a pre built PC from Overclockers - its been fine really besides a few minor hiccups with vista (nothing to do with the pc), but recently it has been hanging in a few games not very often just now and again, I ran coretemp and notice underload my CPU is reaching about 80C sometimes a tad higher.
Could this be causing the hangs? I'm not really up on the overclocking buisness so I had this machine pre overclocked, but since that crash I think some of the bios settings have changed and was wondering If someone could point me in the right direction to what settings it should be at. I have limited knowledge really but I consider myself competent with a PC.
My spec is as follows:
CPU = Quad Q6600 running at 356 Mhz (3.204) x9 Mult
Mem = DDR2 4GB (5.34 Mhz) FSB
RAM 2:3 not sure if you need anymore info on that.
Gfx Card = 9800 Gx2 (The settings in Riva Tuner)
Core Clock: 625
Shader Clock: 1562
Mem Clock: 1000 ( In Riva Tuner)
Thanks for takin the time to read this (If you do ^.^) any help would be appreciated - Sorry for being a noob lol, any additional info I can supply also if you need any, Thanks again.
RAM 2:3 not sure if you need anymore info on that.Gfx Card = 9800 Gx2 (The settings in Riva Tuner)
Core Clock: 625
Shader Clock: 1562
