Need some help around water cooling.
ouch! £1000 for a 3080...
anyway you are the bravest man i know. not only have you not done watercooling before, you managed to buy the most expensive 3080 card on the planet albeit with a water block attached, without knowing the cost of a custom loop.
i take it you dont have any thing watercooled atm? most poeple start with AIO before jumping into custom loop, but fair due for you.
so you need radiator, pump, reservoir (the one you linked is a pump and reservoir combo), lots of connectors, lots of tubing, coolant. all that need to fit within your case give it actually has space to cater for that sort of things
