Need some help, but not sure how to ask.
26 Nov 2005
Doon the Bay (Newcastle)
Hi there,
Bare with me for a few seconds if you can and i will try to explain what i am looking for the best way i can.
I'm developing a website with low skills and knowledge, im using MM Dreamweaver to create it if that effects in any way...and what i've got is a golf map on one of the pages.
What i want to do is to be able to click on a specific part of the map such as one of the holes and bring up the hole details, sort of like a pop up but not. It's vital i stay on the same screen, possibly fade the background while this new window or popup is active, then have the ability to close it and go back to the original page where the map (graphic) is.
In the new popup window im going to need the basic ability to display an image and text, while a desired result would include the ability to move from one popup to the next....eg...you've clicked on hole 5, and you have two arrows back and forward which will take you to either hole 4 or 6. That with a close button would be the exact thing i want to create, so where should i look to find that kind of stuff out?
Cheers for looking.
thanks for the advice guys, looking up the terms you've mentioned, cheers.
