- 9 Jun 2006
I've had this computer for a while now. I replaced the motherboard and hard drive a few months ago and has been working fine for a long time. Although a few weeks ago it did stop on the windows loading screen (bar stopped after a while) and didn't boot. I thought nothing of it and just rebooted and it worked fine.
Today when I switch it on, I get the same problem. I restarted hoping it would fix it...but no. It hung on the windows loading screen again. It spends a few seconds trying to load, then the keyboard LEDs turn off (as normal) but then hangs. Normally the LEDs turn off, then back on again and away into windows we go. I've tried unplugging the keyboard before anyone might suggest it. Although I can boot into safe mode with networking ok.
So I'm assuming there is something trying to start up or be loaded during the loading screen that can't be loaded, thus causing it to freeze.
So any suggestions guys?
Thanks in advance!
Thanks in advance!
