Need some help finding a new gfx card
12 Nov 2005
Hi All....my GFX card is getting a long in the tooth and I have been thinking of an upgrade...however I am hoping to avoid replacing my mobo, cpu etc etc.
At the moment I have a gigabyte GA-Z68AP-D3. If has a PCI Express x 16 slot but I think it's running an older standard of PCI Express 2.0 wheree all the newer cards seem to be on 3.0.
So I guess the help I need is whats the best card for sub £200 that I can get that will run with this mobo?
Thanks in advance for any help!
Which graphics card do you have currently and which cpu. Also what resolution is your monitor. Just to let you know pcie 3 is backwards compatible with pcie 2 and 1.
Currently running a Radeon HD 6900, and I have an intel i5 2500K which is overclocked to about 4GHz.
Ah good news on the backwards compatable stuff...so if I wanted to I could go for a new Radeon RX 470 or something?
Yes.
You won't notice the difference between 2.0 and 3.0.
If you can squeeze a few extra pennies, either the RX 480 or the GTX 1060 will be fine choices.
My basket at Overclockers UK:
Total: £439.98
(includes shipping: £0.00)
that 480 is a good bet at £209 but also the 1060 is a good bet as well as it uses hardly any power there's no real need to have these big fancy coolers on it and with that said a plan blower type will suffice :) personally yes I'd look at the 1060 or 480
Just a note, you night need to flash the beta UEFI BIOS for your board for these cards to work.
Both 480 and 1060 will be a great improvement from your 6970/50 card however :).
EDIT: Just checked your board, only the rev 2.0 has a UEFI BIOS, but rev 1.0 doesn't. Any idea which revision your board is? You can check here: http://www.gigabyte.com/support-downloads/faq-page.aspx?fid=864
It's revision 1.0....is that a good thing or a bad thing?
Don't worry about it. What I would worry about is the card you would like to buy and use. Just make sure to have the latest BIOS available at the time for your motherboard installed before installing the new card.
Most new cards don't have problems with legacy BIOS, it's normally more common I have found when UEFI BIOS is out of date problems can occur with new hardware.
I would recommend a Nvidia 1060 GTX for your system, would be a nice match.
So do u need a uefi bios for new cards to work then. reason why I am asking I just sent a 1070 back on rma what would not boot on my mobo. I checked everything from leads to monitor. I just checked my mobo bios and the pci setting is legacy and I can swap it to uefi. Do you think that could have caused my card not to boot? I have more or less the same setup as Geordie12.
Well there's no UEFI BIOS avaliable so there's a chance the card might not work in your system.
With older boards, sometimes you do, sometimes you don't. There was an issue with older boards not booting with a newer GPU but a BIOS update usually solves it. For GB Z68 boards from what I've seen the fix is usually with the UEFI BIOS.
I have the Rev 1 board. Can anyone confirm this 100% as if I have to budget for a new board it is goint to impact on which card I get.
Thanks for the help all...I decided to go with a RX 470...it's a massive jump from what I have no and for the use I have it's probably plenty good enough.
Ordered with OC yesterday so should be being delivered in the next hour or so!
