Hi there, got my new conroe system today and i'm having problems. Spec:
Antec Tx1088amg Midi Tower Soho File Server Case 480w Metallic Grey
ASUS P5W DH Deluxe
Core 2 Duo E6600
Seagate sata 7200.10 320gb
GeIL 2GB (2x1GB) PC6400 800MHz Ultra Low Latency DDR2 Dual Channel Kit
BFG 3DFuzion GeForce 7600 GT 256MB GDDR3
Hooked everything up turned it on with my windows cd in and everything seemed fine. The windows installation started and got right through to the bit where is says "approx 39 mins remaining". The HD then just seemed to make a repetitive clicking sound and i got this error:
"The signature for windows xp professional setup is invalid. The error code is 17. Data error (cyclic redundancy check) fatal error"
Now when i try to reinstall it boots up but the HD just constantly clicks and nothing happens.
I disconnected the cd-rom and HD and fitted my current IDE HD, which has xp pro on it already. It boots to the windows page where is gives some options like "Start windows normally". When i click it the comp just keeps restarting.
Any ideas on what could be wrong? Any help would be very much appreciated
Gutted it doesn't work
ASUS P5W DH Deluxe
Core 2 Duo E6600
