Need Some Help, Msn making Windows Crash
29 Jan 2005
Hey
I have Windows Xp Pro SP2. After I have been on my computer for several hours and start to shut down my programmes ready to turn off , it restarts. It happens when I exit MSN messenger. I go to exit and after about 1 sec the PC reboots itself ( suddenly turns off, no Windows is Shutting down etc). After it restarts i do not get any error message at all.
I looked in Event Viewer and it tells me this:
Save Dump
The computer has rebooted from a bugcheck. The bugcheck was: 0x0000007f (0x00000000, 0x00000000, 0x00000000, 0x00000000). A dump was saved in: C:\WINDOWS\Minidump\Mini032106-01.dmp.
I have looked on the internet and have not had much luck finding out What and How to solve this problem.
If i close and load msn after I load my PC up then its fine and it doesnt restart.
Any help or suggestons would be greatly appreciated
thanks for your time
Bradlee
