Need some help on pixel sizes...
14 Oct 2007
I am trying to design a leaflet but in A5 size so when it prints in prints in the size I design it in.
I need the Pixel dimensions for A5 in Photoshop please as google give different answers.
If you start a new document, you can select the International Paper preset then choose A5. And if you change the measurements to pixels you'll also get the pixel size (1748 x 2480).
A pixel is of no defined size, so you cannot use it as a measure without reference to dpi. Pixels as a measure work in webdesign because they are controlled by the resolution of the screen.
Using the A5 option as mr.sly says is the right thing to do, but if you really want to use pixels, set your document resolution to 300dpi and your dimensions to 2475 x 1762.
