need some help on resolution please
25 Oct 2016
Hi all
i have to print some wallpaper for a customer . the artwork they have sent is 7 Meg the picture is of woodland .
The area of the print is approx 2.2m x 5m
I did a sample print and the artwork is very pixelated , the customer assures me it is the same artwork that other offices in different countries have used !
i have seen pictures of the other offices and they do look crisp
i'm pretty sure a 7 meg image is never going to look good at 2.2 m x 5m
any idea of the resolution the artwork should be please
the artwork original size is 250mm high at 300dpi
i've sorted it i think , seems when the image is blown up to full size i'm getting 34dpi , not good enough
You will never get good detail with that size of print if you are looking at it up close. Even a 50K MFD camera will show pixels when you look at it closely.
Should be fine if you're standing a few ft away, which if it's wallpaper for an office you usually are. Print off a sample on A4, stick it on the wall, then stand 2-3m back and see how it looks.
